Bizhub C754 Keep Showing Cleaning In Progress
  • Naveed Shahid
    • May 2008
    • 162
    [Misc] Bizhub C754 Keep Showing Cleaning In Progress
    Hello Every One
    Bizhub c754 keep showing Cleaning In Progress After Finishing Print Jobs Some Time In Print Job Machine Stop Printing And Keep Showing Cleaning In Progress
    I Changed Trasfer Belt And Disable Auto Cleaning Trasfer Belt But Still Same Problem
    Plz Advise me
    Reagards
  • Synthohol
    Certified Konica Expert
    • 5894
    Re: Bizhub C754 Keep Showing Cleaning In Progress
    did you slide the shield over and clean the two windows over the sensors under the belt?
    • Naveed Shahid
      • May 2008
      • 162
      Yes i clean sensor still same
      • tsbservice
        Field tech
        • 8053
        Update the Firmware of the machine as KM should fixed this with GD1-70 version.
        • Naveed Shahid
          • May 2008
          • 162
          Thanks for solution
          I update the firmware problem solved but now showing c1144 finisher type fs 534 before updating firmware finisher working fine now keep showing c 1144 after firmware update any idea
          • Synthohol
            • 5894
            check all the belts on the exit assy, ive had them slip off or even the clock disk falls off.
