Need honest feedback on C220 & C224e series toners
  • Don N.
    • Nov 2011
    • 409
    I would like to hear from anyone who has found a reliable compatible toner for these series that they trust and have used for over a year on dozens of machines.
    If you must reply about how crazy anyone is to use aftermarket toner, go ahead. It will be duly noted. Meanwhile we have used a source for years that works fine bit they are discontinuing some lines. There are countless posts where dev and related issues techs are saying all OEM toner was used, so it's not the end all solution. As a 28 year indy, I've made it through quite well using a large percentage of parts that are not from the OEM.
    Thanks for the help!
  • 3ktlc
    • Feb 2018
    • 180
    Re: Need honest feedback on C220 & C224e series toners
    Not these particular models. But the C253 & C554 Have had luck with Polek and Q2.
