Bizhub c235 A02E0Y0-0100-G10-R6 Firmware
  • Mrbytes
    • Aug 2017
    • 6
    Hi guys, I need that firmware revision (A02E0Y0-0100-G10-R6) for my machine C253, send MP to do deal.
    Regards.
  • Synthohol
    Certified Konica Expert
    • 5851
    Re: Bizhub c235 A02E0Y0-0100-G10-R6 Firmware
    i have it on my server.
    become a contributor and ill send you the link.
    • Mrbytes
      • Aug 2017
      • 6
      I have all the manuals of this machine, and the Fiery IC-409 both technical and user, available to those contributors who request it
      Ok thank very much.
      • Synthohol
        • 5851
        link sent!
        • Mrbytes
          • Aug 2017
          • 6
          forgive the mistake but in the title of the thread I have put c235, when in fact it is C253.
          Can you correct it? sorry.
          Best regards
          • Synthohol
            • 5851
            A02e0y0 is the C253.
            Firmware is correct I linked you to.
            • Mrbytes
              • Aug 2017
              • 6
              Yes it's correct, but the one you have sent me really is the G10-R5 not the G10-R6 (although you have it labeled as G10-R6)
              Regards
              • Synthohol
                • 5851
                hey, i relabeled nothing.
                that was right from konica.
                i downloaded it again and when i put it on the server it said its the same file but you are more than welcome to d/l again the fresh copy?
                • Mrbytes
                  • Aug 2017
                  • 6
                  I did not say that it was you, but that you have it (because it is) mislabeled.
                  Watch the capture
                  Best regards
                  • Synthohol
                    • 5851
                    look at the doc that came with fw.
                    everything listed is r5 only boot is r6.
                    see page 2.
                    • Mrbytes
                      • Aug 2017
                      • 6
                      I'm sorry, I did not have this document, you're right.
                      Actually, the firmware that I'm looking for is the one that is referenced in the document that I add, which solves a problem of "IU Life is not displayed".
                      Or in any case the last one that KM launched for the Bizhub C253.
                      Once again forgive my clumsiness, and your loss of time
                      regards
                      A02E0Y0-F000-GGF-R6-500-CHECKSUM-5BEB.pdf
                      • dommyet
                        • Jan 2019
                        • 1
                        link sent!
                        Possible to send me a copy of the R6 firmware for C253 if I become a contributor as well?
                        Just had a C253 for free. Printed about 150000 pages. Desperately trying to revive it.
                        Cannot boot (9 out of 10) sometimes giving me a black screen sometimes with flashing blue / amber start button.
                        1 out of 10 might be able to show me the hourglass and boot into the system showing fax card error (I removed it to swap and reseat the RAMs)
                        HDD was removed and checked NVRAM board as well got a old battery but still has 3V
                        Currently waiting for new pair of RAMs and a CF card for firmware update.
                        Previous owner described the situation was getting worse over time (from completely normal to cannot boot sometimes, then to rarely boots)
                        Any recommendations / advise are greatly appreciated.
