Konica c364. Reset fuser transfer belr
  • DOE
    • Mar 2010
    • 258
    Konica c364 that diffuser section and transfer belt is about to need replaced. Is there a fuse or a chip I can use instead of replacing the unit. Thanks for your advice
  • Synthohol
    Certified Konica Expert
    • 5838
    Re: Konica c364. Reset fuser transfer belr
    No chips. Just read the service manual to see how.
    Quality can't be guaranteed if you reset the belt without actually replacing it.
    • tsbservice
      Field tech
      • 8019
      Plus, there is a chance to ruin another parts life, see topics for developer depletion.
        you run the risk of damaging other parts and having your CQ/PQ go to hell. Replace the page driven parts when called for... would you run your car oil 2X the suggested life?
        • dimprime
          • Sep 2018
          • 6
          hi, to reset fuser and band you just have to reset the fuser or band life with the front door open.
          when hi, to reset fuser and band you just have to reset the fuser or band life with the front door open.
          when opening the door, the start piler turns blue and when pressed it is reset. the door, the start piler turns blue and when pressed it is reset.
          • dimprime
            • Sep 2018
            • 6
            Hi, to reset fuser and band you just have to reset the fuser or band life with the front door open.when opening the door, the start piler turns blue and when pressed it si reset.
