Konica 7155
  • Vesigoth
    • Mar 2008
    • 133
    Konica 7155
    The lead edge registration is off by one inch when original is fed through the ADF and the display is not properly alligned such that when I touch an option on the screen it goes into another option. If you know how to adjust the display and how to adjust the ADF lead edge registration please advice. Thank you.
  • ebm
    • Apr 2007
    • 183
    Control Panel adjustment is in Key Operator mode.
    ADF timing adjust is in 36-mode. Might be hard to adjust if one inch off. Check for mechnical problem also (clutch,rollers,etc.).
    • tech1569
      Senior Field Technician
      • Oct 2006
      • 71
      Konica 7155 Force65 7165 Service manual
      Hope this helps you out.
      RapidShare: Easy Filehosting
      • RockETop
        Curmudgeon at large
        • Apr 2007
        • 171
        Straighten or replace the black mylars on the black paper guide under the ADF. They block light to the sensors.
