Some MFPs stop communicating with the CSRC
  • Bix
    • Apr 2018
    • 1421
    Hello,
    it is about 1 year that I configure the machines with the CSRC.
    Sometimes it happens that some MFPs stop communicating. A solution is to contact the customer and ask to turn off / on the machine from the main switch.
    Once I had to reconfigure the printer connection with the CSRC server because the simple on / off did not work.
    The strange thing is that customers do not make changes to the network and it seems an internal blockage of the machine (in fact they often have them have more than one printer and the others continue to communicate).
    Surely some of you will ask me the model of the MFP. The problem is that this happens more or less in all the machines (bizhub 308e, 4052 etc.) and in other my customers.
    The firmware is updated. Rather! I will tell you about a recent event: In a bizhub 4052, due to another problem, I have updated the firmware for version 4.2. After the update, I go back to the office and find that the machine has stopped communicating with the CSRC.
    This is quite frustrating and can discourage making updates.
    Does anyone happen something like that?
  • monarke4
    • Oct 2018
    • 185
    Re: Some MFPs stop communicating with the CSRC
    Is the equipment in question using the latest network drivers?
    When the communication drops, can the equipment still be seen and connected to on the local network?
    Is this the only equipment site which has this problem, or do you have other installations which experience the same condition(s)?
    You might consider contacting Konica-Minolta Support if no one here has any other recommendations.
    • tech51
      • 846
      Which protocol are you using to communicate?
      • NeoMatrix
        Senior Tech.
        • 3513
        Likelyhood, Windows O/S clean and green policy :
        Check the Ethernet and WiFi adapter settings.
        [x] Allow windows to turn off this device to save power.
        HTH
        • Choclit007
          • Oct 2010
          • 58
          I have had a few devices stop reporting.
          I would delete/recreate them & RAM clear the machines before reconfiguring them only to get 3002 errors.
          I tried using the ConnectionChecker-v1.2.0 software [even using the network cable from the copier] to determine the problem but it would report OK, successful upload & downloading.
          If you can download this utility it may be of some use.
          It will at least confirm that the network [still?] allows access to the CSRC servers.
          • monarke4
            • Oct 2018
            • 185
            There seems to be many choices for Connection Checker, and It doesn't seem 100% clear which one is the right utility.
            Maybe you could share or the name of the company/person who wrote the software?
            • Bix
              • Apr 2018
              • 1421
              I use the HTTP1 protocol
              • tech51
                • 846
                Http is flaky to say the least. We tend to get a more stable communication using email2.
                • Choclit007
                  • Oct 2010
                  • 58
                  From the about box:
                  CS Remote Care Global Services
                  Connection Checker
                  Application Version: 1.2.0.0
                  Konica Minolta
                  Utility was downloaded from Mykonicaminolta.com
                  • and
                    • Oct 2011
                    • 96
                    Originally posted by Bix
                    Hello,
                    If the firmware with function version 4.2 is applied, the setting of TLS1.0/SSL3.0 is turned OFF. Check and reactive this.
                    • Brett GS
                      • Jun 2013
                      • 154
                      Email isnt to stable our side,have to visit machines all the time that stop communicating.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        i dont know if i trust that
                        KM discontinued using port 80 ages ago when they forced SSL port 443 but ive run that software on port 80 and it says its ok.
                        i think best thing to do is just ram clear and reconfig from scratch
                        • EarthKmTech
                          Step aside, noob
                          • May 2009
                          • 2139
                          2 different servers, the one accepting connections on port 80 was at capacity, but still works. Older models don't work with modern SSL so its not going anywhere yet.
                          • copier tech
                            • 8138
                            I am facing this same issue it seems that after upping the function version these machines fail to connect.
                            Where do I need to turn back on these TLS setting please?
                            • tsbservice
                              Field tech
                              • 8003
                              On bizhub C250i
