Bizhub c659 jam code 3205
  • tahashudin
    • Jun 2025
    [Jamming] Bizhub c659 jam code 3205
    Paper jam at exit section ,test all tray papar passage aslso jam,check sensor
  • hgreeniii
    • Jan 2012
    • 4
    Re: Bizhub c659 jam code 3205
    just had this same problem on a 958. The loop sensor now sits at the top of the registration unit. the spring on the actuator can come out of place and not enough pressure will be applied to the actuator.
    • 3ktlc
      • Feb 2018
      • 180
      Yep, those spring actuators have done that before.
      • paulinho
        • Jul 2010
        • 9
        Hi All,
        Was there a solution for this as I currently have a C958 presenting the same intermittent jam issue.
        Loop actuator has been checked and is working fine.
        Cheers
        • escalante
          • Sep 2018
          • 115
          I hope you can use the following technical bulletin of the Bizhub C458Screenshot_20190110-175722_Adobe Acrobat.jpg
          Enviado desde mi SM-J701M mediante Tapatalk
            Originally posted by paulinho
            Hi All, Was there a solution for this as I currently have a C958 presenting the same intermittent jam issue.
            Cheers
            START A NEW THREAD!
            the machine and codes are different.. stop piggybacking your issue on someone elses.
            • kaisa
              • Sep 2019
              • 9
              i have the same problem (C759). loop sensor is OK.
              how did you fix the problem?
              • REGSIS
                • May 2016
                • 434
                That should be jam on entrance of duplex section.
                Duplex drive belt slips because there is no limiter on side of the gear.
                I used to put a rubber cover which are used to cover holes for scanner transport screws (4&8 series).
                Drill a small hole in it (it should be tight) and mount it on a shaft to make a limiter. Belt will never slip again.
                I will post a picture if I still have it.
                Edit: Picture posted
                White rubber marked with red arrow inserted to prevent belt from slipping.
                • izcuintle
                  • 6
                  I had the same problem on 2 machines and by removing key item 31 A795897500 Neutralizing Brush from parts manual. the issue got resolved.Jam 3205.jpg
                  • Albonline
                    • Sep 2008
                    • 1144
                    Hi All,
                    Cheers
                    it will function but its getting shorter. also check the one way roller driven conveyance roller on the right side . if the upper drawers run without jamming I would be looking for roller od shrinkage up the right side of the unit.
                    • HuronMan
                      • Jul 2009
                      • 68
                      Check for bound up bushings in the reverse unit.
                      • rrrohan
                        • Sep 2011
                        • 1976
                        i was recently told by EarthKmTech coworker that 35mm on gate once removed and measured from flat surface was the correct height and if not loosen the left side locked screws to get it to that. also remove neutralizing silver band
