Bizhub press 1060, Fusing belt runs to front side and brokes
  • darwinabad
    • Jun 2014
    • 10
    [Misc] Bizhub press 1060, Fusing belt runs to front side and brokes
    Hi, I have a big problem with my KM 1060 press, I replaced a new fusing belt, but in few pages it brokes, then I replaced fusing roller, bearings and sleeves,
    yesterday I replace these parts but again the fusing belt is broken with only 500 pages.
    Someone can helpme?
  • Synthohol
    Certified Konica Expert
    • 5927
    Re: Bizhub press 1060, Fusing belt runs to front side and brokes
    does the belt have even tension?
    do a nip test to see if there is uneven pressure causing the belt to walk.
    • kenpio
      • Dec 2015
      • 203
      I had this problem with a C1070. After about 80k it started ripping belts. What it was that I did not take one of the packing screws out and I went through a bunch of belts. And at $430 a pop it was not cheap. I did send some back for warranty, but still!! I did bring this up to Minolta and nobody could explain, why after 80k it started doing this. So look for a red screw that is still in the fuser and take it out.
      KEN
      • darwinabad
        • Jun 2014
        • 10
        Thank you, I going to check it,
        • darwinabad
          • Jun 2014
          • 10
          KEN
          Thanks for your answer, I did not find any red screw in my 1060, this machine is bought used and imported from the United States. and it has about 250 thousand pages of use .
