Bizhub C 658
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Bizhub C 658
    Hi all. I have to go to see this recently installed C658 that is producing copyes and scans with a problem at the side of the output readed from the CIS contained into the document feeder.
    So, the copy/scan has about the second half of the second face grayed.
    The hinges of the document feeder are blocked in the non fully open way, hoping this way to not to stress the coaxial black cable that we know well about...
    Tomorrow I'll disable the CIS roller/brush.
    Thanks for sharing your experience and your ideas too
    Aldo
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
  • tsbservice
    Field tech
    • 8007
    Re: Bizhub C 658
    What about different paper sizes? If grey areas pattern is the same with different paper(original) sizes it's not related with original/paper movement. Just giving ideas cuz never touched such beasts.
    Good luck Aldo
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      Re: Bizhub C 658
      Good luck Aldo
      Usually it is a standard A4.
      Thanks for your answer and wish!
        • 23006
        Re: Bizhub C 658
        On previous generations the cable has been the main issue, followed by the CIS, and the converter board (or some combination of the above). That's where I would start.
        • acusso1234
          Tecnico
          • Dec 2008
          • 250
          Re: Bizhub C 658
          I can swap the board because they have a second identical machine. If the problem follows the board..If not I can swap the complete feeder.
