Bizhub C258 (Ineo+ 258) C-9401
  • lebo
    • Aug 2012
    • 88
    Hello,
    new KM Bizhub C258 (Develop Ineo+ 220) after upgrade firmware (G00-S1 > GC3-S1(CZ language)) I got error C-9401 during startup directly after upgrade.
    Machine worked ok directly after unpacking an istallation, I made several copies and print out managment and settings list before upgrading firmware.
    Firmware seems to be ok, both firmware are from the same series both has the same function ver. 4.1 (SW25 set to A0)
    Ok I tried to downgrade to massproduction firmware G00-S1 but still getting C-9401 on startup :-( I checked out all of firmware versions and its sum-codes from service menu and they ar all ok, it means upgrading goes well.
    I tried to upgrade to newest firmware GC1-U8 function ver. 4.2 (SW25 set to B0) but still getting C-9401.
    I checked out (disconnect and connect) wires and connectors between Lamp/scanner-SCDB and SCDB-MFPB and CCDB-MFP but it did not help.
    Lamp/scanner is moving and parking to home position during startup but the lamp is not lighting.
    Thank you very very much for your advices.
    Bye.
    • 23009
    Re: Bizhub C258 (Ineo+ 258) C-9401
    I've already changed out a CCDB on one of these, but it was "C6751", "C6756" errors intermittently. There are a bunch of image adjustments that logically must be done with the CCDB. =^..^=
    • tsbservice
      Field tech
      • 8020
      I will start with LED unit, next flat cable as per manual, rule out CCDB until LED unit go ON and OFF.
      Also I believe newest version is G00-V1, may worth to try it.
      • Brett GS
        • Jun 2013
        • 154
        I have a c558 giving 9401, ccd on back order.
        I have loaded V1 and didnt help at all.
        • lebo
          • Aug 2012
          • 88
          I learned out from service bulletins that C-9401 on the older C258-308-.... can be caused by combination of settings sslv3 and firmware (respective function version)
          • lebo
            • Aug 2012
            • 88
            I think so, I will start with LED unit including cable and second time with SCDB.
            • arahael
              • Mar 2013
              • 97
              You need Q4 firmware. Then set problem isolation ( system 1 or 2 page 3) at scanner unit. Then flash normal cz language
              • lebo
                • Aug 2012
                • 88
                • tsbservice
                  Field tech
                  • 8020
                  Been told by KM rep today that there is a glitch with latest FW and SSL comes OFF by default. Go figure why it would code like that
                  • romario
                    • Jun 2020
                    • 192
                    Hi friend. How are you, do you know that I have the same code c9401, I need the firmware that you mention since I only have the A7PU0Y0-F000-GXX-B6, can you help me?
                    [COLOR=rgba(0, 0, 0, 0.54)]
                    [/COLOR]
                    [/COLOR]
                    thanks
