bizhub C360 with "document size cannot be detected etc
  • axyun
    • Aug 2007
    • 1323
    Working on Bizhub C360 with "document size cannot be detected message" Cleaned optical unit and checked warning symbol
    screen which shows L1 L2 L3
    Does the ccd unit need to be changed and id so is there a calibration procedure? Frank
  • 907tec
    • 434
    Re: bizhub C360 with "document size cannot be detected etc
    Size can't be detected in ADF? On Platen? Both? I've never had a CCD cause this before.
    • Albonline
      • Sep 2008
      • 1154
      get and read the service manual for this ,save yourself a ton of back and forth.
      • axyun
        • Aug 2007
        • 1323
        • rrrohan
          • Sep 2011
          • 1977
          Does it not tell you what component is open?
          • darry1322
            • Oct 2010
            • 817
            Make sure the adf is sitting square on the machine. I've seen people grab the adf and use it to move the machine and get the adf "out of square". The reed switch for the adf closed state isn't matching up with the magnet in the adf.
            • axyun
              • Aug 2007
              • 1323
              Thank you for your input guys. It is definitely referring to the adf when it says coponent is open. When i close the adf it goes away and the other message about
              document size cannot be detected is there. There was on time when i opened and closed adf for a split second it showed the ready screen then went back to message of not detecting document size.
              So what yo are saying Darry makes sense that it may be related to adf positioning. The original document cover looked alright as i remember reading Blackcat saying if the the original document cover wasn't right you could have a non detect issue.
              I guess I will go back and more carefully check adf and sensors etc and take Al's advice and go thru service manual to check on related info.
              You guys are great. Don't know what i would have done in many cases without your help over the last several years. Frank
              • copierdude1114
                • Dec 2015
                • 29
                ADF height may be off
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  Correct, there is a magnet on the front right side, could be not making contact or even missing (common tech school bug)
                  • axyun
                    • Aug 2007
                    • 1323
                    I am a bit embarrassed as I discovered that the PS14 actuator flag was partiallly broken off. Have ordered and expect that this will solve problem Will
                    post result to confirm and thank you for your help + info. Frank
                    • axyun
                      • Aug 2007
                      • 1323
                      Replaced ps14 actuator and spring and adf is working. However there has been a message "No animation guide data available. Contact your administrator."
                      I understand that that refers to the movie data used to show customer hot to remove jams and such. I would not care but machine evidently had a second problem and I don't if it occurred after customer tried going into admistrative settings. The machine won't pring or make copies but will scan the documents from glass or adf. Job goes into que and I noticed that under "status" fo job it says "stopprint". When customer tries to print from computer it says machine is offline.
                      I would not think that the "no animation guide" message would effect printing and copying. Please advise . Your help is welcome and appreciated very much. Frank
