Inceppamento duplex 364e
  • Natale65
    • Aug 2012
    • 9
  • Bix
    • Apr 2018
    • 1421
    Re: Inceppamento duplex 364e
    It will seem absurd but I solved by disassembling and reassembling the FS-533
    • Natale65
      • Aug 2012
      • 9
      the problem does so even without FS 533I had also tried this
        • 23010
        Google Translate:
        hi I'm a technician but in 31 years of experience I've never had a flaw like that
        when the machine is switched on, the machine jams the first sheet in duplex both in print and then in subsequent copies it works perfectly all day if you turn off the machine and switch it on again.
        from an initial check we see that the sheet does not convey in the duplex but exits on the guide fs533 obviously it locks up then after it resumes well
        to you suggestions: confused :: confused:
          what really confuses me is:
          no mention of WHAT has been done!
          did you check sensor operation in SM?
          did you CLEAN the internals?
          what is page count on parts?
          current firmware?
