Bizhub 3851FS
  • Gina82
    • Oct 2017
    • 98
    Bizhub 3851FS
    I have a Bizhub C3851FS that is giving a jammed paper removal message after paper has completed the paper path. I updated the firmware and this problem no longer occurs, to my knowledge, but now the MFP states that there is an open compartment when there is not one. Also the mounting plate with finisher claws makes a horrible grinding noise when going back to home position.
    • 22808
    Re: Bizhub 3851FS
    print or take a pic of error log and post it...
    if you are getting a false jam ( what code? ) check sensors for proper operation..
    what has been done to it?
    sounds like you have gearing probs in the finisher/exit areas.. but without error codes it will be hard to help you.
    did you CLEAN the unit during the service call? ( 1st thing you should ALWAYS DO! )
    life on parts?
    get back to "Trouble Shooting 101"
    • Gina82
      • Oct 2017
      • 98
      Re: Bizhub 3851FS
      I've replaced all parts that needed to be replaced, as well as updated the firmware to get rid of machine giving false jams, but now it says that there is an open compartment when there isn't one, as well as saying there is an original on the glass when there is not
        • 22808
        Re: Bizhub 3851FS
        Then CLEARLY I would start with sensor and switch tests!
        please post error log for further help.
        • Gina82
          • Oct 2017
          • 98
          Re: Bizhub 3851FS
          I've printed a error protocol list and it printed off a sheet of paper that only has T:CNG and I did a sensor check and it printed off a blank sheet of paper
          • Gina82
            • Oct 2017
            • 98
            Re: Bizhub 3851FS
            I ran a full self-diagnostic test and there was not a single N/G
            • Woxner
              • Jul 2011
              • 808
              Re: Bizhub 3851FS
              far as the noise goes there is a lubrication procedure for the finisher shafts. did you do all three pieces of the firmware
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                Re: Bizhub 3851FS
                ..now the MFP states that there is an open compartment when there is not one.
                Assuming all the compartments are shut, (no offense, we all make mistakes)is possible either the wrong firmware got loaded? Or loaded in the wrong order? I remember having a bizhub 950 giving an open ADF message because older firmware was loaded on top of newer firmware. I'm pretty sure it's not possible to load the wrong firmware in this day and age, but those do have an odd firmware update procedure. Double check you got the right files and in the right order.
                All I can say is something is out of sync, bound up, or broken. Those infernal finishers are not fun to take apart. Good luck!
                • Gina82
                  • Oct 2017
                  • 98
                  Re: Bizhub 3851FS
                  I only put one piece of firmware on the machine which updated the MFP controller and the fax board
                  • Gina82
                    • Oct 2017
                    • 98
                    Re: Bizhub 3851FS
                    What order should the firmware be loaded in?
                    • KMFLT3CH
                      • May 2017
                      • 181
                      Re: Bizhub 3851FS
                      The finisher noise on this model is an easy fix, see page 4 of the attached pdf.
                      C3850FS C3851FS finisher mod.pdf
                      • D_L_P
                        Self Employed
                        • Oct 2009
                        • 1196
                        Re: Bizhub 3851FS
                        Honestly, I can't remember the order. The PDF that's listed next to the firmware on the tech support site or the manual should include the instructions. What I do remember is the firmware update wasn't like the any other Bizhub. There were 2 or 3 files in the firmware package and they stressed the order they were loaded was important.
                        Is this still giving an open component message?
                        • n25an
                          • Jul 2008
                          • 1030
                          Re: Bizhub 3851FS
                          which firmware did you use to fix this issue???
                          Sad To Say I Don't Have a Life
                          I do this stuff on the weekends too
                          • n25an
                            • Jul 2008
                            • 1030
                            Re: Bizhub 3851FS
                            C3851Series_A92E0Y0-F000-G00-N5.exe
                            Release Date: 6/26/2017
                            Version: G00-N5
                            was that the firmware???
