Konica c454e no display just hear fans
  • bryant28282000
    • Jul 2012
    • 145
    I have a Konica c454e this morning that when you cut on the main power switch, the red start light lights up than you get a blue display for 1 second than the fans comes on and the display dies. All you hear are the fans spinning no lights or anything but fans running. Please help
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: Konica c454e no display just hear fans
    Check the DMMC (MEMORY ) reseat or replace, also check on the mfp board where the memory slot are they normally crack and as a result the is no proper connection.
      • 23008
      I'll confirm that page memory has brought back the display on a C754e, but the machine wasn't fixed completely. I forget the code ... but I ran the MFP reset tool on a used MFP board to bring this machine back to life. Additionally, the CE password and Admin password were unrecoverable, requiring a call to the hotline to acquire the reset code. =^..^=
