Konica C224e, Is there a way to remove grayed out apps from menu screen?
  • jonbonse
    • Jun 2009
    • 737
    Hi all
  • Bix
    • Apr 2018
    • 1421
    Re: Konica C224e, Is there a way to remove grayed out apps from menu screen?
    have you tried in custom widget settings?
    • jonbonse
      • Jun 2009
      • 737
      I have tried in 'Custom display settings' in Admin but they are not listed, just copy, fax, sound settings etc...
      • Bix
        • Apr 2018
        • 1421
        Perhaps then it is not possible.
        The only way to remove icons is to update the firmware.
        • copyrooks
          • Oct 2013
          • 210
          menu
          utility
          admin settings
          system settings
          custom display settings
          main menu default settings
          • CopierNerd
            • Feb 2015
            • 207
            Just install latest firmware and grayed icons of apps will be gone from the menu screen.
            Cheers!
            • emujo2
              • Mar 2017
              • 1579
              Originally posted by jonbonse
              Hi all
              What apps are showing greyed out?
              • rrrohan
                • Sep 2011
                • 1977
                I thought only the 8 series had widgets
                I have web browser greyed out on ours and I never got to remove it.
                Even on 8 series I don't activate web browser. We don't get Market Place so UK is pointless for almost every customer
                • emujo2
                  • Mar 2017
                  • 1579
                  I'm thinking this is a refurb with some orphaned app on it like Equitrac or Autostore. If so you can go into admin/Open API/ registered APPS. If you set this NO, it will remove any non KM apps.
                  • tsbservice
                    Field tech
                    • 8029
                    While we thinking thread starter didn't bother to answer some questions or to ask more clear/accurate questions...that is pitty, least to say.
