Konica Minolta C458 and Prox Cards
  • progoffice
    • Nov 2008
    • 334
    We just installed several C458 machines in a location where they all use Prox cards to gain access to the building. To simplify the authentication, account tracking and "ID & Print" processing, I proposed the idea of using the Prox cards they are already using to do all three.
    Correct me if I'm wrong, but to do this I will need the AU-205H, the correct driver (A7950Y0-A015-G00-A0_AU-205H) and the proper settings to connect the machines to Active Directory to authenticate the user based on the HEX data from the card?
    I would love to be able to configure each machine the same way so that all users can use all machines without having to manage this at the machine level.
    I appreciate any advice from those that have been down this road before.
    Thanks!
  • kingarthur
    • 1344
    Re: Konica Minolta C458 and Prox Cards
    we did it using the ysoft usb card readers & the ysoft driver on infohub, set authentication to card, then copied the settings from one machine to another via usb
    • progoffice
      • Nov 2008
      • 334
      How do you extract the HEX data from the Prox cards so it can be entered in to Active Directory. Isn't this how the server side authentication works? I read a document posted on this site that specifically references doing this on a C364e. The document I'm referencing is titled IC-Card_ProxC364e.pdf
      Any help is appreciated.
      • B0265
        • Jan 2007
        • 718
        If you activate "LDAP IC Card Authentication" it's possible to allow card self-registration in the security settings.
        In this way if a user swipes an unregisterd card they register it themself by entering the AD crentials at the MFP.
        • progoffice
          • Nov 2008
          • 334
          Thanks for the tip B0265, but I don't see "self-registration" or "security settings" on PSWC. I have LDAP IC Card Authentication turned on. What am I missing?
          • emujo2
            • Mar 2017
            • 1579
            You have it backwards...If you know the number in AD you need to parse the data on the reader to match what you see. This is done by connecting the reader to your laptop, loading the HID drivers, then using the web based tool to put the reader in keyboard wedge mode and removing un needed card info.
            • progoffice
              • Nov 2008
              • 334
              I'm making progress.
              I have the reader connected to my laptop and was able to bring up the web interface of the OMNIKEY. I put the card in wedge mode and I can hear a beep when touching the card to the reader but nothing else happens. There must be something registered in the card because the machine will register the card locally, but I want to know what it's reading so that I can enter that in to AD. I get the idea of self-registration, but I don't see yet how to configure this.
              • rrrohan
                • Sep 2011
                • 1977
                If memory serves me well if it's in wedge mode and you put it on copier if your in a text box when you swipe card on reader it types the card data in text feild. This might give U The info you desire
                • B0265
                  • Jan 2007
                  • 718
                  • emujo2
                    • Mar 2017
                    • 1579
                    You have to have word or note pad opened when you swipe the badge..Reader is acting like a keyboard now. PM me and I will send you a basic 26 bit config file. This will parse out the facility code and all you should see when you swipe is the card ID#. This number is what already needs to be in AD (pager field I think). E
