KONICA MINOLTA C458 Series
  • maximus-1994nr
    • Dec 2018
    • 12
    Hello, I have KONICA MINOLTA C458 Series, is it possible to programmatically send a fax, for example, using the command line or in other ways?
  • habik
    • 2013
    Re: KONICA MINOLTA C458 Series
    You mean like de-compile the driver? Or imitate the fax-driver?
    Sent from portable device using fast cheapset!
    Firmwares HERE
    • maximus-1994nr
      • Dec 2018
      • 12
      Like de-compile the driver. I need to send a fax from MS Access 2016, using VBA or command line or somehow, if possible.
      • Synthohol
        Certified Konica Expert
        • 5847
        add the fax driver as you would a printer.
        then choose the fax "printer" instead of the default in the dropdown.
        hit ok then it will popup a box asking for the fax#
          • 14812
          Why can't you use PC faxing?
          • maximus-1994nr
            • Dec 2018
            • 12
            That I know, is it possible to program it?
            • maximus-1994nr
              • Dec 2018
              • 12
              Because I need to send an encrypted fax
              • allan
                RTFM!!
                • 5462
                Image data or what are you sending?
                Whatever
                • maximus-1994nr
                  • Dec 2018
                  • 12
                  PDF file
                  • Synthohol
                    • 5847
                    use e-fax
                    i have a bunch of HIPPA compliant customers that use e-fax.
                    Secure Fax for Business - Send & Receive Secure Faxes Online | eFax Secure
                    • maximus-1994nr
                      • Dec 2018
                      • 12
                      use e-fax
                      Directly it is possible without using third-party services?
                      • allan
                        RTFM!!
                        • 5462
                        Oops.
                        Instead use fax driver? It is seen as a printer.
                        Printing from Windows 7 command line - Super User
                        Whatever
                        • maximus-1994nr
                          • Dec 2018
                          • 12
                          Oops.
                          I know this, but how in this case to specify the parameters of the fax, namely the number and the other?
                          • allan
                            RTFM!!
                            • 5462
                            There should be a way to do it. Send one to a remote shared printer and capture the packets could have the number in there in pure text?
                            Got no clue what i am talking about...
                            Stick a 64k modem directly into the problem.
                            Whatever
                            • maximus-1994nr
                              • Dec 2018
                              • 12
                              Based on this How to send a PDF as fax from windows command line probably not.
