Paper weight is set to 75-80 gsm, plain white, curl settings set to auto. Can print simplex/duplex normal, no jamming, can simplex 3 hole punch long edge without issue. Only jams with doing 3 hole long edge duplex , but not 2 hole short edge duplex. Tried multiple weights of paper and changed the curl settings for the tray in expert adjustment no change. Firmware is @23 for main body, finisher is at 70. Jam codes 7216, any input would be appreciated. The only thing I wonder is if something was missed on on initial setup pertaining to the finisher and main body?
Help please?
Regards!
A.
Help please?
Regards!
A.
