Konica c35 says calibrating won't copy
  • DOE
    • Mar 2010
    • 258
    I have a Konica c35 that says calibrating all that time and won't allow you to copy. I have clean the lamp and it looks fairly bright to me. I did reset the transfer belt unit approximately two weeks ago without replacing it. I'm not sure whether I should get a new lamp or a new transfer belt for this machine to take care of the problem any ideas
    Re: Konica c35 says calibrating won't copy
    does it display any errors?
    more than likely it is the sensors in/around the iTB unit causing the problem...
    get the manual ..it should be covered in there
    • allan
      RTFM!!
      • 5462
      If the ITU is past due change it also clean the sensors. If there are any near empty toners replace them.
      Check if the machine keeps the time after a restart.
      Hate these machines had a couple do the same thing.
      Whatever
      • 3ktlc
        • Feb 2018
        • 180
        Start with the transfer belt. Clean the sensors.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4718
          I've had that many times when toners are low / empty.
