C253 No Compact XPS
  • B0265
    • Jan 2007
    • 718
    C253 No Compact XPS
    I have a C253 where the compact xps format isn't available for scanning.
    I have upgraded the fw from version from J8 > K7 > R4. It works fine on other machines w FE3 firmware, but not on this one.
    Have anyone else had this?
  • Specilist KVN
    • Sep 2008
    • 79
    Compact XPS is only available on the C415, C550 or C650.
    This is indicated in the manual and the specification sheet.
    • copytechman
      • Nov 2008
      • 947
      I'm sitting in front of one of our c253's with j8 firmware and under file types for scan, compact pdf and xps are separate formats for scanning but are available.
      Have you tried R5 firmware yet?
      Regards
      A.
      • B0265
        • Jan 2007
        • 718
        I found the solution:
        Solution ID
        TAUS0801993EN* Solution Usage
        Description
        Unable toselect Compact XPS as file type of Scan toxx even after upgrading to i-Option firmware (version 88).
        Solution
        CAUSE: Incorrect setting.
        SOLUTION: Please change the setting of dipswitch as follows in order to use Compact XPS. SW No.78: 0x00 => 0x01
        Note : Please be sure to use version 3.1.030000 or later when using PageScope Box Operator.
        SPECIAL NOTE : Solution contribution by KMBT (Japan).
