All Bizhub C224e through C754e All printing Full Color when Auto Color is selected
  • captainrva
    • Oct 2014
    • 100
    I have a customer who noticed their auto color job (1 color page, 7 black pages) was only adding to the full color counter and not the black counter. I opened their job and sent it to a c552 and it prints correctly with 1 color and 7 black but when I send it to any 4e series machine (like the customers), it prints as all color. I have even made new documents in different programs with the same result. I have tried post script and PCL drivers to no avail.
    This is too big of a flaw for konica not to have a fix but I can't seem to find one. Any ideas?
  • qbert69
    • Mar 2013
    • 1152
    Re: All Bizhub C224e through C754e All printing Full Color when Auto Color is selecte
    Do you have a choice in the driver to print black as true black and not process black??? What program was the document generated with???? Adobe? Make sure blacks are ABSOLUTELY BLACK!!![emoji41]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • captainrva
      • Oct 2014
      • 100
      The original document is an Adobe Indesign file but also a PDF and all text is set to true black (c=0 m=0 y=0 k=100). I have created a test document with one word in black and it prints as color as well. In the output, text as black is checked. The document prints correctly to a C552 and when I use the same settings for the C364e, it is printing it as full color.
      • allan
        RTFM!!
        • 5462
        Retraction hammers the machine the transfer belt runs and the color drums are running even if only the cover page is in color adding lost of difficulty to bill correctly, then K cost per copy must be increased. So the machine must stay in one mode for at least a couple of cycles before stopping and starting. Imagine if the transfer retraction and the drum and dev drives must stop every second cycle. Add an additional counter to subtract the cost per copy for the toner not used?
        So in practice those color parts was in use even if its black and white..
        So there is some settings like. Enjoy a slower machine.
        Whatever
        • JR2ALTA
          • Feb 2010
          • 2033
          Make sure the machine and driver are running the same function version.
          • CopierNerd
            • Feb 2015
            • 207
            [ATTACH=CONFIG]41407[/ATTACH]
            Superb! explained very well!
            End of Discussion!
            • qbert69
              • Mar 2013
              • 1152
              [ATTACH=CONFIG]41406[/ATTACH]
              Bottom left corner of the print screen..."setup" which should actually go into the print driver settings...there might be something there you're missing. As far as Adobe goes, you can have some weird settings overrides when multi-layer control is involved!!![emoji849]
              • allan
                RTFM!!
                • 5462
                k=255?
                Whatever
                • qbert69
                  • Mar 2013
                  • 1152
                  k=255?
                  255 is the D-Max amount when your adjusting levels...I know in photoshop, but this is indesign....hard to see the low resolution screenshot!!![emoji849]
                  • captainrva
                    • Oct 2014
                    • 100
                    The C364e is Function Version 7. The driver doesn't show a "function version" but the driver version is 5.3.0. The firmware is G20-M1 which says function version 7.
                    • captainrva
                      • Oct 2014
                      • 100
                      There is nothing in the setup (preferences) other than auto color, full color , grayscale really. The settings are identical to the ones I use on the C552 that prints correctly.
                        • 14812
                        Maybe you have the wrong driver. On my 4e series drivers there are colour settings of Auto colour, Grey scale, and 2 colour. There is no Full colour choice.
                        • captainrva
                          • Oct 2014
                          • 100
                          On my PCL 5.3.0 driver (latest) it says 2-color, but my post script 5.1.2 driver (latest), it says full color
                          • captainrva
                            • Oct 2014
                            • 100
                            I just set up a word document and it printed with auto color correctly. I saved it as a PDF from word and that printed correctly. I set up a new Indesign document and did a preflight to pick up any color and checked the separations for color and there is none but when I print with the same settings....Auto color still adds to color meter. It makes me think it has to be an Adobe issue now but why does it work fine on non 4e machines?
                            I also placed the word document PDF that worked, into a new indesign file and it printed as color on the c364e even after passing the separations and preflight check. It printed as black on c552.
                            I also swapped the driver of the c552 into the c364e and it still printed as color.
                            • allan
                              RTFM!!
                              • 5462
                              Have a look at the problem job and inspect the text with a magnifier to see if it contain color dots.
                              Whatever
