Bizhub 751 jam won't clear
  • inkstrum
    • Apr 2011
    • 14
    [Jamming] Bizhub 751 jam won't clear
    After 15-50 pages print, a paper goes through the vertical transport and gathers in a bunch just prior to entering registration assembly. Area 9 in display picture. When paper is removed, easily since it's exited the vertical transport, it doesn't clear the code. I can get it to clear and print again by running a paper back and forth through top of transport by hand and sometimes by slamming the transport door. I swapped out registration assemblies with another machine and same thing happened. Any ideas?
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 751 jam won't clear
    Jam code please.
    Whatever
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      Just from what you describe sounds like a loose connector, sensor, etc.
      Jam code may help.
      By the way I have a whole working Biz 601 if you need anything.
        double check all sensors and harnesses... jam code?
