FS533 Finisher
  • jwai
    • May 2018
    • 508
    [Misc] FS533 Finisher
    Hello,
    The old version FS533( for C364e ) can install and work properly on C368?
    • 14713
    Re: FS533 Finisher
    Originally posted by jwai
    Hello,
    It lists both series in the installation manual. So I would say yes.
    • jwai
      • May 2018
      • 508
      Re: FS533 Finisher
      Coz I check the part number is a bit different, the last number is 1 for the old version and 2 for C368.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4689
        Re: FS533 Finisher
        The last 2 digits of Kon/Min part #'s is the updated version. As the option or part is modified / updated during several years those last 2 digits will change. I've seen some of those last 2 numbers change 10+ in some cases. Especially with the options that Kon/Min like to use for several years with different machines.
        Example: 9332 1500 "12" means this clutch has been updated 12 times!
        So to answer your question yes you can use it. As long as the first digits are the same. Plus like the other poster said it lists the C368 on the install instructions.
        • Bix
          • Apr 2018
          • 1421
          Re: FS533 Finisher
          Hello,
          I confirm. I use FS-533 without problem with compatiblity
          • jwai
            • May 2018
            • 508
            Re: FS533 Finisher
            Thank you very much !!!
            • jwai
              • May 2018
              • 508
              Re: FS533 Finisher
              Since my experience is , the fax unit for bizhub 215 is A4M2041, and A4M2042 for 226.
              I tried to install #042 to 215 however it displayed error message and the machine freeze.
              • REGSIS
                • May 2016
                • 435
                Re: FS533 Finisher
                Hello,
                I use it for 4 and 8 series moving from one machine to another without any trouble. It's official!
                As I mention on another thread, you can use DF-629 on 4 series, and DF-624 on 8 series. It's not official but it works without any problem.
                Power connector should be modified but it's easy job.
                • jwai
                  • May 2018
                  • 508
                  Re: FS533 Finisher
                  Wooo...fantastic!
