Konica di 550 c0f24
  • RaBe
    Konica di 550 c0f24
    What do You think about that problem? I've tried to find AIDC Sensor (i should clean it), but i've got problem with finding it ... Trouble reset doesn't help...
    can You help me? give some tips...
    greetings
  • copytechman
    • Nov 2008
    • 941
    The aidc sensor is usually right under the middle of cleaning unit below the anti-spill/recovery mylar.. It least thats where it is on the old minolta's i've serviced b4!
    Regards
    A.
    • brent
      • Nov 2008
      • 1212
      this is a common problem. when the machine has not been serviced in a while the toner will spill onto the aidc sensor. almost guranteed you find this out. take the drum unit. remove drum and you will most likely find a toner spill onto that aidc sensor. not the atdc sensor in the dv unit. give it a try
      brent
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        With the age of the machine, it's likely the anti spill mylar on the cleaning section is fatigued and in need of replacement. Been there, done that, bought the t shirt.
        • RaBe
          thanks a lot for Your tips...
          i'll try to do this... then i will say how it goes
          thanks a lot
          Edit: Guys! I (We ) did it!!!!
          It was the sensor (i cleaned it)...
          thanks a lot for Your response... You help me a lot !
          greetings from Poland
          cobiray: what does it mean? "Been there, done that, bought the t shirt." is it a proverb?
          • cobiray
            • Mar 2008
            • 1199
            No, it just means I've seen it before on several occasions.
