Bizhub C35 print problem
  • Konicatech
    • Feb 2016
    • 131
    Re: Bizhub C35 print problem
    Originally posted by Konicatech
    [ATTACH=CONFIG]41668[/ATTACH]
    Page count on parts?
    whats been done?
    looks like belt or Drum
    • allan
      RTFM!!
      • 5459
      Pull out the one of the image units and gently pull the toner roller away from the drum.
      There you will find an in your case a massive buildup of toner on top of the doctor blade.
      Take is outside and blow it out with a blower brush or syringe bulb.
      It my experience you will ultimately need to replace the units.
      Have they been reset? Or rather more than once?
      Using original toner?
      Whatever
      • Konicatech
        • Feb 2016
        • 131
        Done that but no build up of toner, cleaned anyway. Still the same
        Thinking belt?
        • Konicatech
          • Feb 2016
          • 131
          • Toxic
            • 696
            I have this few times on c25 and c35.
            Always was problem temperature difference in room and toner and developer inside IU get moisture, this only happened in winter and autumn rainy days, never during summer.
            1 machine was in room where over night temperature goes under 0 celsius and you can imagine what is scenario when they turn on machine on the morning and fuser get at almost 200 celsius in a minute.
            Partly solved by not turning off machine during night and replacing imaging units.
              Belt looks like this [ATTACH=CONFIG]41669[/ATTACH]
              Belt cleaning blade has failed. replace it unless belt is very worn then replace whole assmy
              • allan
                RTFM!!
                • 5459
                Thinking belt?
                Original toner?
                Units been reset?
                Whatever
