Konica 7135 black copies
  • tander47
    • Aug 2025
    Hi
    i have a konica 7135 and when i try to make a copy by putting the original on the glass it comes out black. But when i use the adf the copy comes out great.
    I was thinking it might be the ccd or the scanner driver board.
    Please help.
  • smiley
    • Aug 2008
    • 615
    maybe your scaner unit are disaligned.try to change ccd board. gud luck.
    there is no glory without sacrifice
    • dogsbody
      • Jun 2007
      • 289
      your scanner is in the right place when using the RADF but something is knocking the mirrors out of place when they move out to scan the page on the platen. you know the ccd is working because it works with the RADF.
      The force will be with you always.
      • montana
        • Aug 2008
        • 392
        hi.when you make copy by the feeder the ccd is fixed not moving.&when you put the original on the glass the ccd is moving to read the original .you can check the movement of the ccd by naked eye if it is correct movement or not.
        thanks for all.i hope it is helpfull
        • montana
          • Aug 2008
          • 392
          konica minolta bizhub 250
          hi everybody.is there anyone coulad tell how to go through servicemode in (konica minolta bizhub 250)
          thanks
          • Luther
            • May 2006
            • 682
            The ccd is in a fixed position , the scanner or optics move, i would say check the movement of the mirror assembly from left to right, either they arent moving correctly or a mirror is out of place, good luck
            • ni311
              • May 2008
              • 658
              utility/counter - > details - > [STOP][0][0][STOP][0][1]
              Konica Minolta Error Codes - Explanations and Solutions
              • eg101
                • Jan 2005
                • 131
                I've seen the mirrors get out of alignment before, check the height on the rear of the mirror carriage.
                • eg101
                  • Jan 2005
                  • 131
                  Originally posted by ni311
                  utility/counter - > details - > [stop][0][0][stop][0][1]
                  utility/ counter/ detail/ stop/0/0/stop/0/1/ 0/0/0/0/0/0/0/0/ end
                  • tander47
                    Thanks for the help Smiley
                    I will try that
                    • tander47
                      thanks dogsbody for the help
                      I will check it out
                      • tander47
                        thanks montana I will check it
                        • tander47
                          thanks for the advise Luther. It looks like the mirrors are good for some reason I think it might be the ccd board or main board.
                          • tander47
                            thanks for the reply eg101. everything checks out on the mirrors
                            • ni311
                              • May 2008
                              • 658
                              Wasn't much easier to thank everybody in just one post?!
