C227 / C287 jamming on colour (J30-03)
  • byronf
    Senior Member
    • Sep 2017
    • 109
    [Jamming] C227 / C287 jamming on colour (J30-03)
    Hi All,
    I have a few of these on the field, we have been replacing fusing units prematurely due to the separation claws breaking. What I notice on these machines is that the client say the jam a lot when they print in color. So I have monitored a few of them and found J30-03 occurs frequently on the machine that break claw. It is obvious that the colour print stick to the fusing roller.
    I have bumped the temperature up but have had no luck I even updated the firmware to G00-W2 with no luck.
    If anybody has had this issue please enlighten me or if there is a part number for the claws.
    Any advice will be appreciated. Thank you[/B][/B]
  • Brett GS
    • Jun 2013
    • 154
    Re: C227 / C287 jamming on colour (J30-03)
    Had this on a few.
    Give you a call tomorow.
    • Toxic
      • 697
      On what media and format this occurs?
      I do not know if I'm doing wrong all the time but I think the fuser temperature should be lowered rather than increase to help paper not sticking in fuser...
        • 23002
        On heavy fill images it helps to increase the leading edge void to 4.0mm - 5.0mm. If you duplex, the same applies to the trail edge void. =^..^=
        • allan
          RTFM!!
          • 5462
          Originally posted by Brett GS
          Had this on a few.
          Fix for the issue?
          Whatever
          • byronf
            Senior Member
            • Sep 2017
            • 109
            This is on normal 80gsm bond. Tried losing the fuser temp as well and the issue still persist.
            • byronf
              Senior Member
              • Sep 2017
              • 109
              Hi I will try this, however it my cause an issue on the field where end users my log calls for image not centralized.
              • Bix
                • Apr 2018
                • 1421
                What is the page counter?
                • byronf
                  Senior Member
                  • Sep 2017
                  • 109
                  13355 clicks
                  But bare in mind that this issue is an intermittent problem across all my machine's
                  • allan
                    RTFM!!
                    • 5462
                    Then its damp paper?
                    Whatever
                    • byronf
                      Senior Member
                      • Sep 2017
                      • 109
                      At first that what the techs kept advising the client, until I bought the one machine in and used it daily for office use to test.
                      Bare in mind these machines +/- 600 belong to one client and 60% of these machines all the end users are complaining about the jamming only on colour prints
                        • 23002
                        Can you try rephrasing that? I missed the point. =^..^=
                        • byronf
                          Senior Member
                          • Sep 2017
                          • 109
                          We have checked the paper for moisture and the problem still persists.
                          We have about 600 of these machines in the city council and they are all doing this.
                          I have brought one of the machines into our office that we are using daily for testing purposes and it intermittently jams only on colour prints.
                            • 23002
                            I'm not going to try to convince you. You can make the adjustments or not.
                            I don't really care if you have 6 machines, 60, 600 or 6000. That doesn't change the answer. =^..^=
                            • byronf
                              Senior Member
                              • Sep 2017
                              • 109
                              Hi All,
                              This issue has been resolved.
                              I used separation fingers from C454e to repair the fuser.
                              Changed warm mode to 4
                              Put toner save mode on
                              It has been a month and the client has not had any issues
                              Thank you all for your help much appreciated
