Bizhub 654 B/W. Clear printing.
  • sonypoland
    • Oct 2013
    • 29
    Hi. There was a failure. There were suddenly bright printouts. It turned out that the developer was out. Then I exchanged the developer. Drum. The printout is still very light almost invisible. HV voltages checked. Help
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 654 B/W. Clear printing.
    Is the image developing on the drum surface?
    Stop the machine in the middle of development and pull the drum out and check the image.
    If that image on the drum is ok focus on transfer.
    Check if the HV contacts on the DV and DR is ok.
    Laser path could also be obstructed with toner.
    Whatever
    • sonypoland
      • Oct 2013
      • 29
      OK thanks. I will check it tomorrow.
      • sonypoland
        • Oct 2013
        • 29
        Printing is still bright. I checked the recommendations from the post. The image on the drum is bright and there are traces of the developer on the drum. Now again, the new developer is transferred to the drum. The question of the time when he will pull it out again and it will be empty.
        • tsbservice
          Field tech
          • 8019
          How did you check HV unit? One reason for your problem may be HV Board 2.
          Can you change it from another working machine?
            • 14755
            I am kinda confused with your use of the word "bright". You seem to be using it in the same context as the word "light". Post a sample so we can see what the pages look like. Thanks.
            • Albonline
              • Sep 2008
              • 1151
              replace the hv units and a new developer. if your mc board isnt already blown.
              • allan
                RTFM!!
                • 5462
                Could also be a bad drum earth or arching somewhere. I will start with the dev tank and the drum unit from another machine.
                I have never changed a single HV board on a KM machine ever?
                Changed them out to trouble shoot but never the problem...
                Had rusted contacts but cleaned those.
                Whatever
