C554e Firmware Issues
  • frizby66
    • Feb 2019
    • 5
    [Misc] C554e Firmware Issues
    Apologies, have a second post with imaging issues but thought better to do this on another post (not to confuse issues). Have an issue with c554e going to sleep and refusing to wake without a power off/on. Have checked the power save settings, have switched off the weekly schedule but still no difference. Below is screen shot of settings. Have also included details of the current firmware, is this the most up to date? If not, any resource for getting the latest firmware?
    Screen Shot 2019-03-01 at 08.09.09.jpgScreen Shot 2019-03-01 at 08.08.56.png
    MFP Card Version A5C10Y0-F000-GDF-M1(00)
    MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
    MFP Controller Linux Base Linux-2.6.26.8-rt16
    MFP Controller Kernel Program A5C10Y0-1C00-GC1-76
    MFP Controller SubSet A5C10Y0-1F00-G00-M6(00)
    MFP Controller A5C10Y0-0100-GDF-M1(00)
    Operation Panel Message Data A5C10Y0-8100-GCE-M1
    Fax Board Controller1 A22M0Y0-4000-G00-12(00)
    Fax Board Controller2
    Fax Board Controller3
    Fax Board Controller4
    Engine Parameter A5AY0Y0-0054-G00-00
    Engine BOOT A5AY0Y0-0055-G00-00
    Scanner A5C10Y0-0023-G00-33
    Printer A5AY0Y0-0050-GC2-31
    ADF A3CE0Y0-0024-G00-16
    Finisher A3EP0Y0-0071-G10-03
    RU
    ZU
    Panel CPU A55V0Y0-8900-G60-00
    DSC1
    DSC2
    Loadable Device Driver1
    Loadable Device Driver2
    SD A3ER0Y0-0071-G00-08
    Voice Data
    Movie Data
    Dictionary Data
    OCR Library
    Panel Sound Data A5C10Y0-C200-G00-00
    MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01
    MFP Controller PIC Image Parameter A5C10Y0-8A00-GC0-06
    MFP Controller System A5C10Y0-1000-GDF-M1(00)
    MFP Controller Print Controller A5C10Y0-3000-GCY-44
    MFP Controller Print Controller Font A5C10Y0-3F00-GCD-40
    MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81
    MFP Controller MIO A5C10Y0-5000-G10-W8(00)
    MFP Controller PIC A5C10Y0-8200-GD6-B2
  • kingarthur
    • 1351
    Re: C554e Firmware Issues
    when you say you've "checked the power save settings", have you set them to the following, "Enter power save mode" set as "NORMAL". "power consumption in sleep mode" set to "DISABLED", there was a bulletin about this a coupe of years ago .
    • frizby66
      • Feb 2019
      • 5
      Hadn't seen any bulletin on this...have updated settings and will see how if that makes a difference :-)
      Any idea on the firmware? Saw something about an issue with SSD firmware!
      • kingarthur
        • 1351
        As far as I'm aware, SSD is updated now with the mass production FW, bulletin number TNGB1400318EN ,
        this is the bulletin number TAGB1400537EN for the machine not waking up
