Bizhub C360 fuser temperature as it relates to wrapping around fuser
  • pick
    • Oct 2015
    • 26
    [Jamming] Bizhub C360 fuser temperature as it relates to wrapping around fuser
    Intermittent wrapping the lower roller on a Konica C360 . Not sure if fuser temperature change will correct or just making a Thick paper change will correct fusing issue ?
    Re: Bizhub C360 fuser temperature as it relates to wrapping around fuser
    page count on fuser?
    worn spots?
    if they are copying/printing and there is not enough white border at top edge it will wrap.
    seen injet paper with heavy fill also wrap
    • pick
      • Oct 2015
      • 26
      I appreciate your reply , the machine does have a good lead edge void as well it has the void top , bottom , trai & lead edge voids . I have replaced fuser mutliple times and will run a couple of weeks . When they do experience it's two sided with heavy saturation . I had another to do the same and when they run two sided heavy saturation while then adjusting to Thick 1 setting no wrapping the roller or jamming . Manual does not talk much on Thick settings , and if 2nd image transfer and fuser temp are affected ?
      • tech51
        • 846
          Thick would be selected in driver
          When selecting thick..paper feed slows..fuse temp boosts
          Is print flaking off page? Or rub off?
          • pick
            • Oct 2015
            • 26
            There in is another question , manual does not give details regarding the changes the machine makes when selecting Thick settings . In reading your reply you mentioned "slows speed of media and increases fuser temp" . Thx for the clarification . Can you give a for instances for increasing and decreasing fuser temp . as a adjustment ? Thx .
              on 80gsm paper it prints and bonds toner properly...
              as you increase weight (gsm) of the paper (thickness) it takes more heat to bond properly...
              slowing paper speed allows paper to stay in fuser longer.. therefore heating the paper more
              this is all explained in the Theory section for each part group Feed-Charge-Transfer-Fuser-Exit
