C224e unable to print under copytrack funtion
  • ck1
    • 485
    [Misc] C224e unable to print under copytrack funtion
    i have one c224 Funtion version 9 when i on the copytrack , but when you send print cant print out . any issue or solution ?
  • allan
    RTFM!!
    • 5462
    Re: C224e unable to print under copytrack funtion
    Check the print log. Does it say "error deletion"?
    Are you using account track or user authentication?
    If you use verify on the driver does that work?
    Switching of SNMP helps?
    Whatever
    • ck1
      • 485
      yes it show error deletion
      Switching of SNMP helps how to set ?
      i can't detect the driver also , need use normal add printer
      i using copytrack
      • Synthohol
        Certified Konica Expert
        • 5897
        in the properties of the printer, check the box for driver popup so you can type in the account code/auth info so it will print.
        • allan
          RTFM!!
          • 5462
          "copytrack" is that 3de party software or do you refer to account track on the machine?
          Whatever
          • ck1
            • 485
            sorry is acct track . now the function version is 9 ? at manual is c224e is last is version 7
            • Synthohol
              • 5897
              read the PDF for that firmware, sometimes they suggest new print drivers however will it print if you enter the acct track password?
              its under the basic tab for auth/acct track
              or under settings tab, authentication you can have it popup a box for the password every print.
              • B0265
                • Jan 2007
                • 718
                Are you sure that the setting of SW25 matches the installed FW version?
                I have never seen a funtion version 9 fw for this model.
                • ck1
                  • 485
                  on my machine device information show it ....
