Bizhub c224e faint COPIES/SCANS
  • Konicatech
    • Feb 2016
    • 131
    Hello
    have a c224e that is printing 100% fine except when you copy/scan from the glass/adf the output is faint on the top half of the page, and fine at the bottom.
    changed CCD so far and problem still persists
    cleaned mirrors still the same.
    Anyone ever had a bad lamp under the glass?
  • mo0651
    • 1054
    Re: Bizhub c224e faint COPIES/SCANS
    Maybe the mirrors got moved out of alignment?
    • allan
      RTFM!!
      • 5462
      Give the front left unsupported corner a tug upwards and see if that helps.
      Whatever
      • Konicatech
        • Feb 2016
        • 131
        What would that do?
        Cheers
          • 14810
          Originally posted by Konicatech
          Hello
          Did you clean the underside of the platen glass?
          • Konicatech
            • Feb 2016
            • 131
            Yes, machine is very clean now! Glass, mirrors, ccd everything
              • 14810
              Can you post a sample?
              • wjurls
                • Feb 2017
                • 498
                Scan a 2 sided original in 2-2 mode and see if both sides do it. The C224e uses a backside scanner in the RADF unit to read the back of the image and not the ccd. This will help narrow down where the problem lies.
                • allan
                  RTFM!!
                  • 5462
                  What would that do?
                  Cheers
                  If nothing else a bit of exercise.
                  Users at the machine would lean heavily on that corner causing it to sag like old tits.
                  Whatever
                  • tsbservice
                    Field tech
                    • 8020
                    Good catch but that really depends on what DF machine has DF-624 or DF-701.
                    • wjurls
                      • Feb 2017
                      • 498
                      That's right.. I forgot that dual scan was an option not standard..
                      • Ado Mmoloki Moepedi
                        • Jan 2022
                        • 32
                        Did you ever manage to slove the problem?
