BH C-351 stays in warm up
  • garrycmsi
    • Jun 2015
    • 22
    [Misc] BH C-351 stays in warm up
    Hello,
    I have a customer that replaced the yellow IU before counter maxed out now machine just says warming up ready to scan.it will not move past this state if I put the old IU back in then the screen changes to image stabilizing and after a minute or so ready to copy. do I need to reset counter or is the image unit bad?
    Thank You all in advance any input would be helpful
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: BH C-351 stays in warm up
    take a look at level history for atdc levels, make sure all IUs are around the 6.-7. range IIRC
      • 14725
      Originally posted by garrycmsi
      Hello,
      To me it seems pretty straight forward. The old one works, the new one doesn't. Try another new IU.
      • garrycmsi
        • Jun 2015
        • 22
        Thank You copier addict seems logical to me as well I just wanted some confirmation because I am a kyocera tech not so familiar with bizhubs. I just happen to have a customer that has one of each I didnt want to order another IU with out being sure. do you think a reset chip would work? any input would help.
        • CompyTech
          Super Tech
          • Feb 2011
          • 706
          In the past I've had those imaging units do that. Sometimes it could take 10 minutes or more before the IU resets and goes into Stabilization mode.
