network stting does not show in administrator seeting
  • Gulbadin
    • Nov 2017
    • 22
    i was using bizhub 600 as a printer but after turning off dhcp the network setting does not show any more so i cant connect to it from pc.
  • allan
    RTFM!!
    • 5462
    Re: network stting does not show in administrator seeting
    Any message on the panel that shows something like ARP request?
    Unplug the LAN cable and give the machine a good 10 to 20 min after restart to see if you can access it.
    Could be that a network speed selection issue.
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5808
      print the config page?
      - Press the Utility/Counter button.
      - On the touch screen, select User Setting.
      - Select Printer Setting.
      - Select Print Reports.
      - Select Configuration Page.
      - Select the paper tray to print from (if prompted).
      - Press the Start button.
