7145 f 23-1
  • smiley
    • Aug 2008
    • 616
    7145 f 23-1
    hi guys please help me how to cleare this code.
    there is no glory without sacrifice
  • copytechman
    • Nov 2008
    • 929
    From the manual:
    F23-1 PCL connector detached
    When the PCL was being turned
    ON prior to the start of initial
    charging, a PCL abnormality was
    detected 15 times in a row at the
    specified intervals after the specified
    period of time.
    PCL (Pre-charging exposure
    lamp) connector
    CB (Main body control board)
    Located on the main charge assy, try replacing the whole charge unit as a test first (dont forget the reconnect the one connector onto the drum unit) and if still ng it could be an icp on the main driving/control board.
    Regards!
    A.
    • redime
      You forgot to plug your lamp back in after cleaning the drum...
      • smiley
        • Aug 2008
        • 616
        hi guys i try to chnge the whole drum unit from working one and the pre exposure lamp are connected but still the problem exist.where can i find the icp in the drive assy.? please halp me.
        • redime
          main board is in the rear behind the back plastic cover and right side cover, then there is another board to the right of that, behind another metal cover and plastic side cover. Be sure to test out all the ICP's with the connectors UNPLUGGED. Having the connectors in can give you false positives. Unplug all the connectors, pull board out, test em all. The board displays ICP1, ICP2, ICP3 etc.
          • smiley
            • Aug 2008
            • 616
            thanks ridemi ill check it.and ill let you know if i solves the problem.
