C3850 main screen button change?
  • mrfuser
    • 1617
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: C3850 main screen button change?
    From the user manual:
    [Registered Key Settings]
    To display: [Utility] - [Administrator Settings] - [System Settings] - [Registered Key Settings]
    Not sure if you can change them like on the later models because the C3851 control panel is more similar to the 4e and 8 series than the C3850 is, if I'm remembering correctly. But who knows since I'm old and have C.R.S.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • mrfuser
      • 1617
      • srvctec
        • Oct 2009
        • 827
        Just discovered something that might help. I was working on a bh284e and had to update FW to the latest version. The machine was on function version 3 and had the web browser and external apps buttons on the menu screen but were grayed out. I updated the FW to latest and then set correct function version to 7 and then those buttons disappeared.
        So, check that you have the latest FW installed for the C3850 and that the correct Function Version is set. Maybe that will do the trick.
        • tsbservice
          Field tech
          • 8007
          [Utility]
          • [Administrator Settings]
            • [System Settings]
              • [Custom Display Settings]
                • [Main Menu Default Settings]
          • B0265
            • Jan 2007
            • 718
            There must be some Openapi application installed, what is shown if you press that button?
            • rrrohan
              • Sep 2011
              • 1977
              Always wondered how to get web browser menu off a 365 thanks
              Use the API Manager app and see if something got installed and just remove it
