Bizhub 4050 CE password
  • nathicana
    • Aug 2008
    • 335
    Can someone help me get into service mode? It asks for CE password and now says "locked after failed attempts" because I kept trying the wrong password.
    Is there a way to clear that and what is the CE password?
  • nathicana
    • Aug 2008
    • 335
    Re: Bizhub 4050 CE password
    I got in by stop 09317 then 92729272
    I can't find logical format though in state confirmation
    Is there a way to logical format on a Bizhub 4050?
      • 23009
      Does it have a HDD? =^..^=
      • nathicana
        • Aug 2008
        • 335
        Yes I can see that it has an HDD but not where to do the logical format.
        I need to overwrite the hard drive and get a data report to print out.
        On other Konica Minolta machines the hard drive needs to be formatted following the overwrite.
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1257
          This is not really a Konica, it's a relabled Lexmark. You will find what you are looking for in the Utility-----Settings menu under HDD Settings. The table supposedly looks like this:
          Administrator Settings - Security Settings
          HDD Settings--Check HDD Capacity
          Overwrite All Data--HDD Overwrite Method---Execute
          HDD Format
          HDD Encryption Setting
          Overwrite HDD Data
          Not sure about how you can get that Data report to print out though, maybe somebody else here can answer that for you.
          • Bix
            • Apr 2018
            • 1421
            • nathicana
              • Aug 2008
              • 335
              HDD Format
              Overwrite HDD Data
              Maybe there is not a report
              Thank you
