6501 pf-603 issue
  • Arcadian
    • Feb 2010
    • 218
    6501 pf-603 issue
    Im getting tray 4 and 5 not opening also the pfu main door not detecting that it open, the trays are going up and down if i open them manually. The copier detects the tray fine, just doesnt report the door
    is open.
    Ive changed the PFU board 3 times , Do you guys think it might be the printer controller board!??!
    anyway to check for another switch is bad?!?!? Or maybe a procedure that i am not aware of to detect door switches or thereof.
    Thanks for the help!
    Arcadian
  • Albonline
    • Sep 2008
    • 1150
    Re: 6501 pf-603 issue
    is open.
    Arcadian
    pf 602?
    • Arcadian
      • Feb 2010
      • 218
      Re: 6501 pf-602 issue
      yes PF-602 SORRY
      • Arcadian
        • Feb 2010
        • 218
        i found the issue
        its was a molex connector on the bottom of the pfu unit, behind some wire cables i didnt see.
        left side if the pfu board, hard to see.
        pushed it back in and door released and pfu door detected.
        so all good
        thanks
