Bad quality prints, grey banding
  • jacanape
    • Feb 2019
    • 22
    Hi,
    The prints from my Konica Minolta bizhub C552 exhibit a wide gray line on 5 cm from the bottom of the print in the course direction of the machine.
    The thicker the paper, the darker the line.
    Does anyone know what the problem is and how I fix this?
    Thanks, Peter
  • allan
    RTFM!!
    • 5462
    Re: Bad quality prints, grey banding
    Sure seen it a lot can identify it by the symptoms.
    Condition is called techususgetusus and remedied by a dose of payatechusus.
    Not a gambling man and no fixtures to look at(sample print or even what you have tried...) but would guess the odds is in favor of the transfer belt.
    Whatever
    • jacanape
      • Feb 2019
      • 22
      This is a scan of a print on 300grs paper.
      Maybe this helps... ;-)
      • allan
        RTFM!!
        • 5462
        Looks like a combination of run down parts.
        Whatever
        • copyman
          Owner / Technician
          • Sep 2005
          • 4765
          The one pic looks like magenta and the other grey. Usually grey is waste toner. Agree with allan, start with transfer belt than drums/developer units.
          It would really help if you would give more information, like consumable life counts, what you did so far, etc. It's a Saturday and not busy why I'm even replying. I had posted before if someone needs help and they won't at least provide life counts, what they did so far,etc. then I won't help them.
          Providing pictures is great and a lot of help but some additional information is necessary, especially on quality issues which can be so many different things causing it.
          • jacanape
            • Feb 2019
            • 22
            Ok , I Will send more info on monday. Thanks
              yeah.. seems hardly anyone gives life counts... work done... error codes....
              that why a lot of threads go 15 -20 comments... " Pulling Teeth "
              Phil B. " The Dentist "
              • jacanape
                • Feb 2019
                • 22
                Hi Phil, thanks for the effort!
                There is still no work done to solve the problem. There are no error codes.
                The only thing I did was cleaning the transfer roller and the corona's with the cleaning rods.
                The correct pic I have sent was the gray one. (the other was magenta after scanning in colormode...) So there is no color in the smudged lines on the print.
                The problem arises especially for printing on thick paper (250-300 grm)...
                • tsbservice
                  Field tech
                  • 8053
                  If the bands are in parallel with paper feeding direction I would start by stopping A3 paper in machine to eliminate fuser. If fuser is OK next thing to check is your K drum(it's due replacement) and/or TBU.
                  • jacanape
                    • Feb 2019
                    • 22
                    Hi,
                    What do you mean by "stopping A3 paper"?
                    Sorry, my language is Dutch, so I don't always understand the meaning. Google translate makes a mess of it... :-)
                    • tsbservice
                      Field tech
                      • 8053
                      Just make copy/print on A3, it's longer and easy to stop it(for enduser) partly in fuser by opening machine door.
                      Next you can examine jammed paper, this is basic print quality troubleshooting.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4765
                        You posted you cleaned the transfer roller. What did you use to clean the roller? Did cleaning make it worse? Those bands not in direction of paper feed would be caused by something like the transfer roller, etc.
                        • jacanape
                          • Feb 2019
                          • 22
                          I cleaned the roller with offset glaze remover. The cloth was black after cleaning. Cleaning did make it al little bit better, but not for long...
                          The bands are in direction of paperfeed.
                          • jacanape
                            • Feb 2019
                            • 22
                            OK so I did that. The paper that comes out of the fuser on the upper side has banding, the lower side has none.
                            I also made pictures of the K drum, maybe this helps...?
                            • Bix
                              • Apr 2018
                              • 1421
                              Sorry it's not very clear.
                              Before entering the fuser how is it?
                              If it is clean before entering the fuser, then it is the fuser.
