DU-105 alternative (PRESS C1070)
  • qais90
    • 4
    [Misc] DU-105 alternative (PRESS C1070)
    Hello everyone,
    I want to know if someone uses non original drum (and cleaning blades) for DU-105 for the KM C1070 / C2070,
    Because genuine units are quite expensive, is there an alternative way ?
    Thanks in advance.
    • 23010
    Re: DU-105 alternative (PRESS C1070)
    Nope. =^..^=
    • Gaffers01
      • May 2011
      • 335
      The DU104 which is a bit cheaper is the same drum just has a different plate on the drive end which you can swap with old drum unit.
      • qais90
        • 4
        thanks for replies
