BH C654 FS-534 finsher skew
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Skewed paper output when the eject unit fingers are misaligned, normally can be fixed by moving them back into aligned position and does not frequently reoccur.
    Have one unit that goes out of alignment more often. Question:
    What causes the fingers to go out of alignment? Both are driven by the same motor/shaft. The belts slipping could do this I guess but they seem fine. C654e fs534 eject unit.JPG
  • tsbservice
    Field tech
    • 8021
    Re: BH C654 FS-534 finsher skew
    Do search here for: FS-534 alignment plate wearing
    You will find some interesting posts.
    • blazebusiness
      • 1257
      Thanks for replying. I am aware of the alignment plate wearing issue........ this issue is for the eject unit pulleys/fingers misalignment and ideas as to what causes it. Completely unrelated to those worn alignment plate issues.
      • allan
        RTFM!!
        • 5462
        Like you said they are driven together. Have you removed the belt to check the inside on them and the pulleys? Looks ok?
        Even if bushings wear the belt tension can drop.
        Whatever
        • blazebusiness
          • 1257
          Something certainly seems to be slipping......if clean/lube doesn't resolve it, guess I'll replace the individual parts....looking at my parts catalog , don't think Konica sells the entire eject unit.
          • tech51
            • 846
            The eject unit comes as an assembly complete with motors etc.
            Incidentally the one in the picture looks quite worn. We also have had cracks appearing in them which causes all sorts of issues.
            • tsbservice
              Field tech
              • 8021
              Sorry for that, my bad.
              Looking in FS534 manual shows this as whole unit: A3EPPPDE03 Ejector Unit
                • 23009
                There are no less than (6) bulletins changing that eject assy. Order the assy and be done with it. =^..^=
                • blazebusiness
                  • 1257
                  Sounds like good advice-----thanks to all for the replies.
                  • rrrohan
                    • Sep 2011
                    • 1977
                    my theory is users are putting hand in to grab paper instead of waiting for it to eject and one finger smacks into their hand and put its timing off compared to the other one.
                    • allan
                      RTFM!!
                      • 5462
                      So we need to electrify those fingers. 9kV should alter there behavior.
                      Whatever
