C8000 C2220 & Toner Door Sensor
  • Choclit007
    • Oct 2010
    • 58
    While troubleshooting a C2220 code (1st transfer not turning) the toner door sensor has stopped responding properly.
    The message to close the Toner Supply unit remains after closing it & turning the screw in.
    PRCB CN125B Pins 1 2 & 3 (Top Left of connector) should be Ground, signal out & Vcc of 5V for the sensor per the wiring diagram.
    With the sensor unplugged i am getting 0 / 5 / 0
    Plugged in I get 0 / 2.3 /1.2
    Occasionally if I unplug the sensor & plug it back in the message will clear (ie tell me now to close the front doors) but this is random.
    The connector on the PRCB to the Right has 2 Vcc points that give a good 5V reading (as do the power connectors on the right side of the board)
    The PRCB was swapped & gives the same readings.
    If anyone can confirm those voltages it would be appreciated
    (I am currently trying to source another Photosensor)
    FYI the C2220 code - M9 / PRCB / DCPS/4 all swapped; wire harness inspected as best possible
    RL3 is not turning on - do not know why
    Firmware has been kept up to date
    The First Transfer Belt does not appear to be faulty / short screws are being used where necessary / worn ball bearing recently changed
    Any help appreciated
