Konica models that can be used to print from phone
  • DOE
    • Mar 2010
    • 258
    Which Konica models are you able to use your phone to print too. We have a customer wanting one and some confusion with the company we buy from whether it can be done or not. Please let me know the models that you are currently using for this application
    • 15066
    Re: Konica models that can be used to print from phone
    If you are wanting Airprint you need C224e or later.
    If you want to use the KonMin printing app you need C253 or later
    • emujo2
      • Mar 2017
      • 1579
      Almost every device going back 10 years or so is supported by page scope mobile printing. The newer devices support Bluetooth, NFC, ect. There are wireless options that can allow the mfp to broadcast it's SSID for wireless printing.
      • Synthohol
        Certified Konica Expert
        • 5922
        google is your friend
        Compatible devices
        The Konica Minolta Mobile Print app is compatible with the following Konica Minolta devices:
        Colour: bizhub C754e/C654e
        bizhub C754/C654
        bizhub C658/C558/C458
        bizhub C652DS/C552DS
        bizhub C652/C552/C452
        bizhub C650/C550/C451
        bizhub C554e/C454e/C364e/C284e/C224e
        bizhub C554/C454/C364/C284/C224
        bizhub C368/C308/C258
        bizhub C360/C280/C220
        bizhub C353/C253/C203
        bizhub C287/C227
        bizhub C266/C226
        bizhub C281/C221/C221s
        bizhub C3351/C3851/C3851FS
        bizhub C3350/C3850/C3850FS
        bizhub C3110/C3100P
        bizhub C35P/C35/C25
        bizhub C266/C226
        bizhub C20/C20P
        AccurioPress C2070+IC-603
        AccurioPress C2070P+IC-603
        AccurioPress C2060+IC-603
        AccurioPrint C2060L+IC-603
        bizhub PRESS C1085+IC-602
        bizhub PRESS C1060+IC-602
        bizhub PRO C1060L+IC-602
        magicolor 4750EN/4750DN
        Mono: bizhub 958/808/758
        bizhub 754e/654e
        bizhub 754/654
        bizhub 652/602/552/502
        bizhub 558/458/368/258
        bizhub 554e/454e/364e/284e/224e
        bizhub 367/287/227
        bizhub 423/363/283/223
        bizhub 306/266
        bizhub 4750/4050
        bizhub 4700P/4000P
        bizhub 4020/3320
        bizhub 42/36
        bizhub 40P
        bizhub PRO 1100
        bizhub PRO 958
        bizhub PRO 951
          • 15066
          I'm not sure if you are aware, but KonMin is scrapping Pagescope Mobile
          • Synthohol
            • 5922
            yes, pagescope is bye bye.
            the list is for Konica Minolta Mobile Print. that's the replacement IIRC.
            Konica Minolta Mobile Print App - Professional Print Management Solutions at Konica Minolta
            • rrrohan
              • Sep 2011
              • 1977
              unless your using account track/user auth I find AirPrint/Mopria is easier
