Problem with c308 and error c-d010
  • Azaelneo
    • May 2019
    • 7
  • arahael
    • Mar 2013
    • 97
    Re: Problem with c308 and error c-d010
    Ssd,HDD,? 3 firmware sata solutions? Try disable HDD under service mode and check
    • darry1322
      • Oct 2010
      • 817
      The first thing to try is to go into Administrator made and format the HDD.
      • tech51
        • 846
        There is recovery firmware that can be used to recover a main board. I would ask your tech guy if that’s been done.
        Also ask if sata firmware V4 is loaded.
        If all this has been done and it still codes, then I’m afraid a board is your only option.
        • Azaelneo
          • May 2019
          • 7
          the hard drive is a traditional type. my technician don't know what firmware he installed. I'm a pc technician and I tried to insert a disc and format it from the technical menu. after the physical formatting the error appears. if I unplug the disk it works regularly but without many features!
          • Woxner
            • Jul 2011
            • 853
            do the logical not the physical format. cd010 means the hdd is not formatted. i had this same problem on an 808. had to replace main pwb in the end. if the main pwb is bad it wont formatt hdd. but try logical its takes 10 min or so.
            • Azaelneo
              • May 2019
              • 7
              I tried the logical, the error does not appear but the disk is not detected after restart.
              • Bix
                • Apr 2018
                • 1421
                After logical formatting, the HDD is disabled. You have to enable it in the service.
                • Azaelneo
                  • May 2019
                  • 7
                  how I find the menu of attivation?
                  • Bix
                    • Apr 2018
                    • 1421
                    System 2 > HDD > Installed.
                    Sometimes it takes 15-20 seconds before Installed becomes selected.
                    But if the HDD has been disabled, chances are you have made a Clear All. Are you sure you have logically formatted it?
                    I advise you to call a technician.
                      • 14972
                      The HDD is not disabled after doing a logical format!!! The movie data is required, that's all.
                      • Azaelneo
                        • May 2019
                        • 7
                        After activation, the copier is slow and freezes
                        • Bix
                          • Apr 2018
                          • 1421
                          You're right, in fact I corrected myself in the next post.
                          However, if the printer is slow or frozen, you try to turn it off for 10 seconds and unplug it.
                          Hang up and see what happens. If it continues to give problems, a technician is required.
                          • Azaelneo
                            • May 2019
                            • 7
                            • tulintron
                              • Jul 2014
                              • 668
                              First of all, try:
                              Physical Formation;
                              Logical Formatation;
                              Installing firmware movie data;
                              Check if the HD is enabled, as was said by friends in previous posts.
                              Good Luck!
