C458 fax issue
  • darry1322
    • Oct 2010
    • 817
    C458 fax issue
    Here's my issue: when sending a fax the customer enters the fax number from the fax destination entry screen, presses start, and the doc pulls through the adf and the job finishes almost immediately. The job log shows the number dialed but shows as an email job rather than a fax job. Incoming faxes are good. Under Admin mode, fax settings, only #5 Function Settings button is active and under that option only a couple of items ( Function ON/OFF Setting, PC-Fax Permission Setting) are active. So you have very few options for setting fax info.
    I've tried: unsetting and resetting the fax. Uninstalling and reinstalling the fax. Updating to latest firmware. Formatting HDD. Replacing the fax board.
    Has anyone seen this before? My next steps are factory reset and/or MFP board. It's a managed deployment machine and I hate to start that all over from scratch if it's just some obscure setting that changes the fax operation.
  • copyrooks
    • Oct 2013
    • 209
    Re: C458 fax issue
    Try turning off the Prefix/suffix setting
    Should be
    Admin settings
    Network Settings page 2
    Detail Settings
    Prefix/suffix settings
      • 30216
      Re: C458 fax issue
      Fax set to US setting?
      go over the install sheet and recheck settings
      • darry1322
        • Oct 2010
        • 817
        Re: C458 fax issue
        Checked and rechecked. Thanks.
          • 30216
          Re: C458 fax issue
          If its sending via email it thinks it's a IFAX internet fax should be a setting for default faxing
          In the administrator mode, select [Network] - [Network Fax Setting] - [Network Fax Function Settings], and then set [I-Fax Function Setting] to [ON] (Default: [OFF]).
          • darry1322
            • Oct 2010
            • 817
            Re: C458 fax issue
            One thing that worries me is that they said it was also not printing confirmation pages so they looked up instructions for that setting on youtube and tried to set it themselves. Not sure what they may have played around with.
            I'll check that setting for I-Fax as well. Thanks.
              • 23008
              Re: C458 fax issue
              I have seen this ... not sure what model. I'll strain my remaining memory cells trying to remember the details. =^..^=
              • darry1322
                • Oct 2010
                • 817
                Re: C458 fax issue
                Should be
                Admin settings
                Detail Settings
                These were off but there was another prefix/suffix setting in Service Mode that was turned on. KonicaMinolta helpdesk tech directed me there. When I turned this setting off my issue resolved.
                • tsbservice
                  Field tech
                  • 8013
                  Re: C458 fax issue
                  KM has tool to check default Software switch settings or compare them between machines, it may be helpful in such cases.
