C244 reset tool not working
  • darkocg88
    • Jan 2018
    • 63
    So basically, can't enter the service menu, default password not working, dealership claims they haven't changed it.
    Next step was reset tool. Machine isn't reacting to inserted drive into maintenance hub.
    Any other ways to hard reset it or is my reset tool faulty? Or is there possibly other default pw for 244 other than 9272 x4
    Thanks in advance
    Sent from my Moto E (4) Plus using Tapatalk
  • Reed
    • Feb 2011
    • 258
    Re: C244 reset tool not working
    You can try 12345678 or once in the service mode press " Stop, 0, Clear" This will take you into another service mode from there look for "CE Authentication" There are two choices that have CE in front of them. One allows you to change it and the other to turn it off. You can turn it off so that no password is required. There are two choices that have CE in front of them. One allows you to change it and the other to turn it off. I always turn it off
    • darkocg88
      • Jan 2018
      • 63
      Can't enter service mode at all
      • Reed
        • Feb 2011
        • 258
        I'm confused I thought you got to the service screen where it is asking for a P/w?
        • darkocg88
          • Jan 2018
          • 63
          Yeah that's the point where I'm stuck. So what do you mean, I enter that command on counter keyboard?
          • Reed
            • Feb 2011
            • 258
            yes before pressing any more keys do not try to enter a p/w .. Press "stop, 0 , Clear
            • marvin_PL
              • Jun 2012
              • 24
              Take off rear left cover,then check if cable of sensor usb service port USB is connected
              • rrrohan
                • Sep 2011
                • 1977
                yeah just escalate the problem to dealer support. provide them with the token key it generates then they will provide you with a password reset key.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4711
                  Did you try 12345678 or 1234567812345678. Or try 9272 one or 2 times.
                  I change all my passwords to 12345678, same as the admin.
                  Most of the time I turn off CE password.
                  • arahael
                    • Mar 2013
                    • 97
                    in some older ver firmware there was bug. open/close front door then menu key xD
                    • tsbservice
                      Field tech
                      • 8019
                      I'm with marvin and rrrohan on this one. First check your thumb drive-not everyone is accepted.
                      Check Maintenance USB port and lastly contact(if possible) support to get reset code through LMS.
                      • darkocg88
                        • Jan 2018
                        • 63
                        Answer from official dealership is that their USB key isn't working. I actually know the guys that work there and company that has this machine has contract with my company for maintenance.
                        • tsbservice
                          Field tech
                          • 8019
                          So you telling us that your company who has contract to maintain the machine and dealership that you asked for help are failing to enter SM. That's is weird, what was your initial problem?
                          • darkocg88
                            • Jan 2018
                            • 63
                            Service mode password unknown.
                            • tsbservice
                              Field tech
                              • 8019
                              Ask your dealership, they should know their stuff better than that.
                              Good luck
