PRT/IR L-1 L-2 L-3 L-4 Bizhub C284
  • Marquee
    • Sep 2018
    • 6
    [Error Code] PRT/IR L-1 L-2 L-3 L-4 Bizhub C284
    Hello,
    An enduser has a Konica Minolta Bizhub C284 which gives the following errorcode: PRT/IR L-1 L-2 L-3 L-4. We've tried to enter the service mode to reset this errorcode. I don't know for what reason but the normal service password doesn't work.
    Can somebody please help us out? Is there a way to reset the service password?
    Thanks in advance for your cooperation.
    Kind regards,
    Marquee
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Re: PRT/IR L-1 L-2 L-3 L-4 Bizhub C284
    The "L" codes mean all the drums have reached end of life. There is nothing to "reset" in service mode, new drums have a chip on them that reset the counters. There is a known issue with this machine that if you let the drums run way past their life they can short out crashing the developer unit(s). Developers cost $400-500 each for color units, $150 for black!
    • allan
      RTFM!!
      • 5462
      What service password did you use?
      Whatever
      • Marquee
        • Sep 2018
        • 6
        Ok, so if we replace the drum units for new ones (and the developers aren't cracked), you think the system will work properly again?
        • Marquee
          • Sep 2018
          • 6
          the one that starts with 9... etc.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4765
            Did you try the "9" password 4 times? If not usually 1,2,3,4,5,6,7,8
