konica c364enot scanning to smb through bt business router
  • cooke123
    • May 2019
    • 3
    Hi all
    my customer has just changed their bt business router and now scan to smb from their konica C364e no longer works but they can print.
    The pc holding the shared fsmb folder and the MFD are both connected by network cable through the router. i can ping the MFD from the pc and connect via the web browser however i cannot ping the pc from the MFD. I have logged onto the router and the routers firewall was not set up to block anything.
    any ideas out there
    cheers Paul
    • 30222
    Re: konica c364enot scanning to smb through bt business router
    Originally posted by cooke123
    Hi all
    any ideas out there
    cheers Paul
    Are DNS settings and gateway same?
    • cooke123
      • May 2019
      • 3
      yeah all the same, i tried pinging the ip and the computer name just in case
      • Synthohol
        Certified Konica Expert
        • 5826
        Make sure port 631 and 465 are open on the router. That would interfere with scanning.
        • rrrohan
          • Sep 2011
          • 1977
          its pretty rare for a router to block internal traffic, normally its WAN traffic thats filtered. if it is blocking it would normally be manually applied by IT. but blocking SMB seems odd. can another PC on network browse the folder thats shared? what SMB version are you using
          to test that the PC simply isnt responding to ICMP try pinging it from another PC.
            • 30222
            Can you ping the router from the copier?
            What antivirus is running on PC?
            • SmellsHot
              Head Tech
              • 512
              When the pcs reconnected to the network they had to reselect....public, work, or home. By default some settings such as sharing are disabled. Go to advanced sharing settings and look there
              Everyone has the right to be stupid. Some people just abuse this privelage more than others
              • Synthohol
                • 5826
                if it worked 100% before the router change, nothing should need to be done with the copier at all afaic.
                if a direct laptop or something has no issues it has to be router related.
                but for gits and shiggles try putting the copier on DHCP and reboot it.
                see if you can have 2 way communication then.
                let us know.
