bizhub C364e with FA14 C-4091
  • Bix
    • Apr 2018
    • 1421
    Hi guys,
    I want to consult with you about some problems with a bizhub C364e.
    This is a used machine that I purchased and has one of the latest firmware version 7 G20-M1.
    The machine gave no problems in the laboratory. After 1 week from delivery to the customer, the machine started to freeze and returned FA14 and sometimes C-4091.
    This happens after the machine wakes up from a stanby. I've already formatted the HDD but he doesn't seem to be the culprit. If in fact the machine does not go into standby, it seems to continue to work properly (scans, printing, etc.)
    I downloaded a special FW which indicated the solution of the FA14 problem but it had no effect. For now, the solution that seems to work is to disable Sleep Mode.
    Today, another C364e have as this one that I have just described, reported me an FA14 (without C-4091) but after reboot it seems to work again.
    Has anyone had a similar problem?
  • allan
    RTFM!!
    • 5462
    Re: bizhub C364e with FA14 C-4091
    Try changing network speed from auto to 100mbps full duplex.
    Ok you can ignore that.
    Back to firmware/environmental trouble.
    You say it is a lab...
    What kind of lab?
    Whatever
    • Bix
      • Apr 2018
      • 1421
      Hi, I mean my lab office. I picked up the car to analyze the problem. Apparently the removal of the sleep mode did not work. The fw I rewrote and I did the self diagnostic, without solution
      Maybe ssd? Thx
      • tsbservice
        Field tech
        • 8020
        Try following procedure:
        1. Do [Initialization] -> [Clear All Data]
        2. Do HDD Logical format
        3. Do SSD Logical format
          • 14815
          I just had a BH284e with a C-FA14 today and the HDD ended up being the culprit. We have had several of the OEM HSGT 250gb hard drives fail on us.
          We have been installing Seagate 500gb HDDs in their place without any problems. The machine doesn't recognise the full 500gb, but that doesn't seem to cause the machine any trouble.
          • Woxner
            • Jul 2011
            • 851
            if you pull theses hdd's out and read the partians on a laptop you might find they have 10 or 20. this is why most of the hdd crap out. i delete the partians and reformatt and they work jusat fine.
            • Bix
              • Apr 2018
              • 1421
              Hi, here is an update:
              - replaced hdd of another C364e. Unfortunately no effect.
              - replaced new ssd. Unfortunately no effect.
              The next step I think will be the MFPB.
              The screen, after waking up from a standby, continues to freeze and return FA14.
              • tsbservice
                Field tech
                • 8020
                As a last resort before changing MFP run full diagnostic and check memory modules.
                At what FW version is machine now?
                • Bix
                  • Apr 2018
                  • 1421
                  hello, in full diagnostic everything is ok.
                  fw version 7 g20-m1
                  Every day the problem becomes more random. Now when I turn on the printer, the red LED does not flash to indicate scanning preparation and the printer freezes.
                  • allan
                    RTFM!!
                    • 5462
                    Would you be able to disable the HDD for a day or so?
                    Whatever
                    • tsbservice
                      Field tech
                      • 8020
                      fw version 7 g20-m1
                      Ok, it's latest base FW, I will go with latest special version, just in case.
                      One thing that bothers me is that in your service shop machine worked well, it may be perchance that problems arised at customer's site...but double check network settings and setup.
                      • Bix
                        • Apr 2018
                        • 1421
                        Hi, it worked well before delivery by the customer.
                        Actually now also in my office it gives problems. I ordered a new motherboard.
                        • Bix
                          • Apr 2018
                          • 1421
                          Hi, bad news: changed HDD, SSD and today the motherboard. Unfortunately none of it worked. The display sometimes freezes and shortly afterwards FA14 always comes out
                            • 14815
                            Have you tried running the machine with the HDD uninstalled and unplugged?
                            Was the HDD you installed new?
                            • Bix
                              • Apr 2018
                              • 1421
                              Hi, now I have replaced the monitor from another machine and it seems to work. However, the problem does not occur in the other machine.
                              However now I have a new problem. With the new SSD and MFPB, the CE Password and Admin password do not work.
