C3110 Losing Sttings when turned off
  • Gaffers01
    • May 2011
    • 335
    We have a c3110 that when its turned off and then on again,
    it asks to enter the date and time etc back in.
    i know very little about these machines but presume there some battery that's gone bad somewhere?
  • Bix
    • Apr 2018
    • 1421
    Re: C3110 Losing Sttings when turned off
    Hi, if the plug is not disconnected, maybe the settings remain.
    However it is a CR2032 battery that you find by removing the rear center cover.
    • copier tech
      • 8219
      I had the exact same issue, updating the fw did the trick.
      However it didnt loose the network settings or address book literally only the date & time so not a big deal. Dont shut machine off at main switch use control panel sleep button.
      • rrrohan
        • Sep 2011
        • 1977
        I recall firmware patched this issue.
        • Gaffers01
          • May 2011
          • 335
          Hi thanks for your help i updated the firmware and problem disappeared.
